ErikTande
Supporting Member
- 1,522
- 595
- Dec 17, 2012
Centennial,
Colorado
I did my first real tuning tonight.
I recently installed my 1000cc injectors, afpr, walbro 450 and new fuel filter. Fuel pressure is 37/38 psi, and I did a boost leak test tonight all the way up to 24psi right before this log, so no problems there.
I got it idling correctly and took a cruise log and used MAFCompadjust to smooth things out. That changed my airflowperrev a bit, but I read that doesn't have to be .25 depending on your setup.
Anyway, it's idling and cruising ok now, so I did a couple pulls. Everything seemed ok (a little rich maybe, but ok) so I cranked the boost up to 17.5 and took the log attatched. There's a couple 3rd gear pulls at the beginning, then I cruised home (I had a little fun in 2nd gear a couple times as I got closer to home, 17psi is fun
Anyway, how do I tune my WOT? Also, when I'm cruising, even slight or moderate acceleration is dipping down below 11's for AFR, I assume that's too rich for 20-30% throttle. Or is that fine? Sorry, total newb here. Log is attached, I let it idle for about a minute at the end.
Thanks!
-Erik
*EDIT* File was too big to attach apparently, here's a link (right click, save as)
http://www.eriktande.com/erik_tande_log_2014.03.28.elg
I recently installed my 1000cc injectors, afpr, walbro 450 and new fuel filter. Fuel pressure is 37/38 psi, and I did a boost leak test tonight all the way up to 24psi right before this log, so no problems there.I got it idling correctly and took a cruise log and used MAFCompadjust to smooth things out. That changed my airflowperrev a bit, but I read that doesn't have to be .25 depending on your setup.
Thanks!
-Erik
