I think i got walked on
You can check for crank play without taking motor apart. I bought my TSi with huge play in my crank. Grab the harmonic pully at see just how much it moves in and out. I guess there is suppose to be "some" play, but not alot.
i don't know about you but most manual transmission mitsubishi's i have ever driven do that. i would check your motor mounts because if they are in great shape then your suspension takes car of it and its not as harsh.
i feel like crankwalk was such an "issue" because it was treated similar to how the media blows up news out of proportion.
My car is dirty... you think it's crankwalk? :rolleyes:
Sounds like your flywheel/pressure plate is warped... drop the DSM lingo of which you have no clue how to use.
do you feel this while releasing the clutch from a stop or while in 1st gear in stop and go traffic and you are already in gear on and off the gas?
if i understand this correctly i think its perfectly normal.
has this always done this?
What kind of motor mounts do you have?
  • Wanted 6 bolt NT water pipe
    • chrisman287
