I need some help
TDX
163
Sep 14, 2003
Naples, Florida
Hey all - This has been bothering me for some time now - I currently have ingalls camber kit installed on my car - i took off the tokico's and put my stock susp back on and its still doing it- ever since i installed my camber kit my car has been steering to the right - i sent it to the shop and they said the alignment is good and my wheels are balanced // they recalibrated it but it still veers to the right - anyone ever had a problem like this before? thanks for your help in advance.
Patrick
Many 2Gs list to the left. This can cause them to have more right camber than left. If they used to camber kits to equalize the camber (without, of course, making the car level, since camber kits don't help with this), then they probably have the two kits set differently. This could cause the car to pull to the right.
Keep in mind that having a zero thrust angle (i.e., equal rear toe; it's a term leftover from RWD-only days) is critical to getting a car to go straight. So look again at the aligmment printout and verify this.
- Jtoby
