I need some help guys
tsilover
254
Oct 20, 2002
I just had a new engine and an act 2600 installed and I have some problems. First, my idle is surging, i have a biss screw to install so I think that'll solve it. My other problem is that when the rpms are high, 5k, and i depress the clutch, the rpms dip below 1k ans sometimes the car stalls. This does not happen when i just pop it out of gear. This is obviously a problem when I'm driving at higher speeds. Also, the car runs different with the clutch depressed when i'm stopped and in neutral. Does the clutch need to be adjusted? Thanks a lot.
~JJ~
  • Wanted 6 bolt NT water pipe
    • chrisman287
