I need some 1G interior harness pictures.
1992awdlaser
3,050
29
Dec 5, 2004
Wallace, North Carolina
I need pictures of the way the interior harness runs under the dash from the driver side to the passenger side. Also, I need to know where the ground goes to on the passenger side of the harness.
I have the entire harness taken apart so I could remove any unneeded wires. It is now time to put it back and I can't figure out a few things about how it ran. I wish I left at least some of the tape on so it would keep its form.
Just in case anybody is wondering, this isn't hard to do. The hardest part is putting it back together, which is a pain in the ass for me. But you can keep it simple by leaving some tape on it so it keeps its form.
Bringing this back up. I have some time to work on it now and would like the wiring to be ran like factory. I am going to put it together to try and get to the track this Sunday.
The ground goes into the body just above the bar that goes under the dash from side to side. You can see it in the first picture. I took these pictures before some major cleanup sorry about the mess and I hope they can help you. It's all back together now, let me know if you need any specific pics and I will get them.
I now have a problem because of this project. My right turn signal stays on even with the key out. I can't turn on the left turn signal, the right will just stay on. I had to unplug the flasher unit near the ecu to turn it off. God I hate electrical work.
What do I need to do?
Edit: Neither turn signal works. When the flasher unit is plugged in, the rear lights stay on even with the key out.
So, hazards work, turn signals don't, rear lights stay on with flasher unit plugged in.
