Spoolin98
- 1,646
- 23
- Feb 1, 2004
Easton,
Pennsylvania
Well first off, the car has been sitting for like 2 months barely being driven. The battery kept dying and I kept jump starting it. So I drove it for the past 3 days, not boosting at all because when I log I am knocking like crazy.
Just idling, if I rev the motor a bit, I get 1-4 counts of knock.
I cant press the gas at all without getting knock.
I retarded the timing a bit by turning the CAS counter clockwise, that didnt help. I did a bosst leak test, found 2 leaks. Fixed the one, the other is the TB shaft seals. That did nothing, still knock. Lastly, I let the car idle till the gas light came on and went to Sunoco and put 93 in it, still knocking like crazy...I dont know whats going on.
On the highway, if I drive next to the median, I can actually hear the detonation whenever I press the gas. What would make me knock like this without even boosting?
I logged the car while boosting..I had 4 counts of knock till around 4300rpms, then its jumps to 40-45 counts of knock for the rest of the pull. Timing started at 20* at 2700 rpm, then slowly dropped to around 15* till 4300rpms, then it drops to like 5* and flutters around there for the rest of the pull.
Whats going on here? I know something is DEF wrong, I just dont know what and how to fix it. Thanks in advance
