I must be slow: how do you install ingalls
blcknspo0ln
DSM Wiseman
7,772
101
Jul 31, 2003
Central, New Jersey
I cant for the life of me figure out how to install these damn camber kits :thumbdown . someone PLEASE kindly provide photos or a walk through on how to install these sumofabitches. oh btw, I got the front and rear camber kits: 8 silver bolts, 4 metal adjusting things, and an assload of metal washers. If i recall, isn't there supposed to be 4 gold brackets also? if so, I got jipped and can I reuse them?
:thumb:
This is the full front and rear kit. Yeah sounds like you got jipped on the four gold bracket plates for the rear. The gold plates give you 1 degree of adjustment in themselves. However, you can reuse your stock brackets. Take the stock brackets off. Put your washers behind them in equal numbers (obviously). If you use more than 2 washers, you will need to use those 8 silver bolts. If you use less then a 2 washer level, then you can reuse the stock bolts. I had to use 4 layers (i.e. 16 total) for my Tokico Illumina and Springs.
For the front, just take off the joint at the upper control arm and replace with your ingalls. The stock fronts are kinda roundy while the ingalss has a square head and are adjustable. I just adjusted the fronts to the center and tightened up the bolt.
Merry Christmas. For some reason, the Ingalls kit only came with instructions for the rear. But that's what it sounds like you need help with.
