luv2rallye
DSM Wiseman
- 8,634
- 1,369
- Jun 7, 2003
Minneapolis,
Minnesota
My 99 GST has saged over the years and now has way too much negative rear camber (and resulting toe out) which has wiped out the inside rear tires. I would like to get the car back to factory height, if that will correct the camber, or even higher (as I sometimes run checkout on pro rallys and could use more ground clearance). Is there a cheaper way to do this without buying new springs, etc?
I heard something about coil overs will adjust height. If they do, what are they, what are they primarily for, how do they work, and what's the cost? If there is an easier way to adjust height back to normal (or higher) that will correct the camber, would this be better than having to put in camber kits, etc? Or is the camber kits the way I must go? I'm experimenting with the bolt/washer mod now but of course it doesn't raise the car and I just realized that maybe just raising the car back to normal would solve all my problems.
I don't race the car. I just want minimum tire wear with normal driving. I'm willing and able to work on the car to correct this (I do all my own work and am experienced - just need a little help in this new area). Anyone have answers or ideas?
