i have a pinkish bov
CABLODSM
98
Nov 4, 2014
joliet, Illinois
It's recirculated. Has no brand.
trying to figure out what brand it is.
the bolt on the top has a nut and when u loosen the nut . It just loosens off and nothing adjusts.
noticed a flutter sound.
also since I upgraded my t25 n stock smic to a big 16g ported and fmic.. is it normal for on startup to start up more agressively than it did before.
sounds great on startup
I have a 96 gst[DOUBLEPOST=1417488504][/DOUBLEPOST]Don't have a picture car is at my mom's i live an hour away
Yeah looks like the sticker less one.
But the bolt that's on the tip mine doesn't have a hole for a Allen key
these things have strong spring pressure... my 62mm borg warner wouldnt push it completely open until it hit a full 20psi of boost.. great for high boost application but not for cruising unless you cut a coil off
I'm ganna buy a new one anyway since I don't know what this one is since it came with my car..
also has a aluminium intake pipe to the maf with no name .. must be ebay
I'm not able to get pics till the weekend
But it looks like the ngr if it didn't have that sticker
Greddy knock-off! Lol ebay. And there's nothing wrong with them. As long as the diaphragm looks good and doesn't leak. Then you just have to mess with the spring to get it right for your setup. You can do this by finding a diff softer spring or cutting a coil off the original. When I was using the greddy and knock-off bov's, I was able to find a perfect spring combo for my setup. The bov worked and sounded great held boost just fine. My only problem with them is the adjustment screw on top. They strip out super easy and I would have to rig it with a bolt holding from the inside. Became a huge headache and after 3 diff ones LOL I got a hks ssqv!! :) I actually just bought another hks to use on my gvr4. You can always source a 1g bov, those work great and can be found pretty cheap. Or if you want one that will bolt right up to your flange. Check out the ngr bov, it's the way the greddy should be! ;)
Ok finally I have a picture sorry for the delay
