DSMULATOR
- 188
- 0
- Sep 19, 2006
B Ville,
Rhode Island
I had a clutchmaster 6 puck clutch and a fidanza flywheel. I shimmed the pivot ball out and made sure the fork was sticking out in accordance to the RRE tech page. I also installed a new clutch master and slave and added a SS line straight to the slave, eliminating the restrictor/accumulator. It didn't hold for crap so after 2200 miles I changed it. The flywheel was fine, i sanded it down to get a smooth finish and I installed an ACT 2600. Now it won't disengage. There is no air left in the lines but it won't fully disengage. The fork/TOB contacts the pressure plate with very little free play if any, so do I need an extended rod?
