ivj
- 55
- 0
- Sep 12, 2006
Renton,
Washington
Hey everyone!
I just got my new car, a 97 eclipse gst (in red) and I'm reading to truly make it mine (by taking it apart
. I wanted to ask a question in the tranny forum, but I get a "you can't post here". How come?
Anyway, here's my question:
When I bought this car, the first gear was a little rough going into. I didn't know much about trannies or synchros back then, but I bought it (and I don't regret it). Recently, the first gear started popping out when you start to let go off the clutch. It happens about 50/50, also applying force to the shifter seems to help a bit. Once you start driving, the gear doesn't pop out.
It's a nasty problem which causes me to start in 2nd gear half the time and smell my clutch.
Anyhow, my neighbor, who's a car mechanic told me that it's the synchros that are worn and need to be replaced (since apparently they also do the job of holding the gear in place).
Now I could spend $1,500 and pay someone else to do it, or I can do it myself. What I decided to do is to buy a used civic tranny and take it apart and put it back together, and repeat that about 20 times til I can do it with my eyes closed. Then I'll get under my car and pull my crap out.
So basically I wanted to ask for some general advice.
1) Are there any repair manuals that I can buy that would help me out?
2) It would make sense to replace the synchros on all the gears, right? Where do I buy them and how do I find out my tranny's model # or whatever? (it's stock)
3) While I am at it, what other things should I replace? I hear the throwout bearing also should be replaced when doing tranny work. Is it true?
4) I can't decide whether I should have my current steel flywheel lightened (to about 15 lbs), or buy an aluminum one (9 lbs)... My neighbor tells me that your ACT flywheels and clutches are good for a short amount of time performance and would break down after a few thousand miles. Is it true or not? Can someone suggest a good tradeoff between a performance and reliablity for a clutch and flywheel?
5) Also, do I buy a new clutch or get the current one "grown" somehow?
6) While I'm at it, what else should I check out in there?
Any other advice would also be helpful! Thanks guys and Mitsubishi! You make getting laid easy!
. I wanted to ask a question in the tranny forum, but I get a "you can't post here". How come?Anyway, here's my question:
