How long untill i can post in tech forums
Status
Not open for further replies.
The idea here is that you need to help your fellow dsmers when you can. Watch the forum and when you know the answer to someones problems help them out. Hopefully they will return the favor and recommend you for reputation points which will(when you get enough points)bump you to a proven member status. We all had to go through this. I personally am an ASE certified mechanic and have been for 10 years and I went through the same thing. Help other members when you can with correct info and in no time you will become a proven member. If you read all the rules it explains this to you . Good luck and remember to help each other. Travis
Read the damned rules and find out for yourself.
It's laid out to where even an idiot could understand it.
Then again..
Status
