1G I built a exhaust leak tester
NeMiZiS
Supporting VIP
2,116
51
Jul 25, 2007
Palmer, Alaska
I read online of some one doing something similar.
I went to home Depot, got a plumbing 4" rubber cap it was like 4.99.
The 4" was closer to 4.5 inside diameter.
It fit my SRS exhaust tip perfect.
I took an old PCV valve drilled a hole in the cap and bolted it into the rubber cap.
Then I took apart a old tire valve stem.
Then used a piece of hose to connect the valve stem to the PCV valve nipple.
Total cost 5 bucks and old parts laying around.
Sprayed soapy water on suspect areas.
Worked great found out my O2 housing bolts had worked loose and started leaking, also found a crack in my exhaust manifold. Yay!
