dsm-onster
DSM Wiseman
- 8,592
- 132
- Jul 11, 2004
Bloxom,
Virginia
Ok. I am driving around and everything is fine. I pull into a parking lot an park my car and the car stalls out like i havn't disengaged my clutch. But i have the pedal pressed to the floor.
So all at once, i can't disengage my clutch. So I pull her down. Put in a LSD insert, new SBR 3500 clutch and pressureplate, new throwout bearing, new release fork. No clutch disengagement. No biggie. I just wanted an excuse for my wife to get the new clutch.
New slave cylinder. No clutch disengagement.
Rebuild master. No clutch disengagement.
1/4 inch longer slave rod. No clutch disengagement.
Shim up the release fork with a couple of washers. No clutch disengagement.
Each time, I bleed using a vacuum line and a clear container and a friend pumping as i tighten and untighten the bleeder valve until i see no air bubbles in the clear container.
I see the slave move the fork. How far should the fok move? 1/2 inch. 1/4 inch. 1 inch? What's going on??!!
P.S. I also have my pedal adjusted out so that there's about 2-3 threasd left on the master rod.
