2G Hunting idle/high idle
stirb
Feb 9, 2014
Bakersfield, California
1999 gst, I've been having a idle issue for a while, a couple months ago my idle would hunt and run high but if I just disconnected the battery for a whle to clear the code it would go away. Now it isn't
I get a code for the TPS and IAC, I have replaced the iac twice and the tps once, the TB has been cleaned three times and the tps adjusted many times.
My mechanic said I should replace the TB as a whole, what do you guys think?
It is throwing two codes
1. For the tps, tps was replaced as OEM part, used from a local company
2. IAC which has been replaced with a autozone one then a carquest one.
I have no boost leaks expect from the Biss screw which is very very small.
I have noticed if I'm rolling along in the car doesn't matter the speed, the idle jumps from 1k-1800k, but when I come to a complete stop the idle is a little more steady and just idles a little high around 1400k-1500k
just because you have a code for those sensors doesn't always mean there bad . you have to check your wiring to the sensors and make sure the proper voltage and grounds are there .
Thanks, I'll check the wires, I took a look at the link and I'll go down the list... I have noticed my cruise control stopped working one day. It doesn't come on. Do all models have a FIAV?
