Hows This Setup Sound?
Mock
112
May 6, 2009
Jarrettsville, Maryland
I have almost everything but injectors so far.
Evo 3 16g
Extreme Psi Install Kit
Greddy 24v FMIC
Walbro 255
SAFC II without logger
Boost and A/F not wideband gauages
Hard Up and Lower Innercooler Pipes
o2 with dump
Turbo XS MBC
Stage 4 CC Clutch and Flywheel.
I Still Need 650cc Injectors.
Do I need a FRP????
I wanting to push about 18-20psi on all stock block and head.
here's my exhaust mods sorry wasnt under original post.
My mistake gentleman. Heres the deal:
1000cc injectors
ECMlink v3
Hallman MBC
gt30r
racegas
28 psi
full exhaust gauges etc etc
HKS 272 cams
Run a 10.9 like corey from STM!
are you saying that you don't think that his setup could benefit from link?
Did I say that? No
I said for the setup he has right now a SAFC would be enough and from what I can see he cannot afford Link at the moment so I don't see why people keep telling him to get link when hes made it clear he can't afford that right now so give him helpful info on what he CAN work with at the moment.
My helpful info is to save up for something. You also said that if he want to go to a bigger turbo later then get link.
Your point? You can only tune up to 650cc injectors safely with a SAFC and if he plans on running a bigger turbo down the road he'll most likely need bigger injectors which will require him to tune with Link. Also, you NEED to get a logger and WBo2 asap so you know what your car is doing or your gonna be running into even bigger problems.:thumb:
i just want the 16g until tax season next year. then i was planning going bigger with link. i just wanna have alil fun right now with out Fing my motor up. just something SIMPLE. SAFC should be pently i thought.
ok?? this helps me how??
It is just a general guide if you want to go fast and what it would take to get there...I would save up for ecm link v3 because you will need more function and capabilities when you continue to mod your car.
Im running
Big 16g
650cc FIC
no fpr...had one but didnt like it
255 walbro
S-AFC 2
fp2 cams
turboxs bc
wideband w/o logger
19 psi
no plroblems at all 12.8 1/4 time....:thumb:
Finally something that is simple and helps me out alot. I understand where everyone else is coming from but i dont want to much just enough to cut the job. Thanks again Boosted did you tune it your self?
Yea I tuned myself but I have a JMF intake on the way so im gonna get it dyno tuned after that....and as for the afpr i didnt know much about it and I didnt have a guage and the car seam to not spudder after i took it off. I wrolly didnt know how to tune it right but im perfectly fine w/o it and my local shop (Abel Racing) said its a waist of money. So I sold it
Ya, that is like saying "Pfff, forget about installing a boost guage-I can just listen to the turbo to find out what boost I am running at, and shout at it when I want to raise the boost".
Lol no hard feelings, just had to add that in! :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
