How would you diagnose a missfire at 4K Rpm with ECMLink?
arbiter
159
Jul 21, 2008
Irun, Europe
Good evening,
I finished my clutch work today on the 1G, and when I took it for a drive on the neighboorhood, I could not rev past 4K, no matter if wot, 50% pedal, or slightly pressed, it would not pass 4K with noise like missfiring. Spark plugs are brand new, installed with the clutch work. so perhaps a boost leak?
Anyway, how would you approach this knowing the car has ECMlink? Can it help?
If you installed ecmlink yourself then you would have had the option install the wire to your clutch pedal for nlts. If you wanted to.
Since you dont know what it is im assuming its not there. And possibly you may have activated it via laptop on accident.
I dont have my laptop in front of me (I havent hooked nlts up on my current car and has been 8years since I did my last one.) but that setting is in one of the tabs. Just make sure its not checked.
Hi, I did g get into high rpm but only on speed, I am not able to rev stopped. When doing wot, I got cel on high rpm.
I also got my o2 reading dancing all the time from 0.02 to 1 volt.
Might it be some kind of ecmlink feature? I think I read somewhere about rev limit, valet mode, and more. Do you know what I mean?
If you rule out NLTS, fuel cut or ignition cut. There is another possibility that i can think of.
Have seen someone with a very similar issue and it ended up being there downpipe flex section crushed on itself. It wasn't even possible to tell without looking inside of it. The exhaust size shrank down to a nickle size and prevented the engine from reving.
