how to tell if my car is a base, rs, or gs
97gen2
39
Dec 15, 2011
upper valley, New Hampshire
just want to know how to tell what model my car is? its hade a lot of mods b4 i got it so its hard to tell. all i know is its a 420a n/t, 5speed, w/o sunroof, and stock low rise wing i dont know if that really makes a diff.
More than likely its an RS. The GS had a sunroof, The GST w/o but it doesnt have the 420A obviously. Check the rear brakes and suspension. The RS came with drums and w/o a rear sway bar. Also with black exterior door handles and sideview mirrors. Hope this helps.
ty that really helped me mine came with black exterior door handles and sideview mirrors and drum brakes now next q is can i put a rear sway bar in it if it didnt come with one?
i was hopein that there is a letter or # code in the vin that would tell me
There sure is: Decoding VINs
4th digit covers airbags and seat belts, 5th FWD or AWD, 6th is the price class, and 8th is the engine set up.
Here is a tech article on how to install a factory rear sway bar on your 420a 2g that didn't come with one from the factory: http://www.2gnt.com/index.php?d=Rear%20Sway%20Bar%20Install
http://www.rtmracing.com/xcart/product.php?productid=16736&cat=1524&page=1
NOTE: FWD DSMs that come with no rear sway bar from the factory will need additional factory mouting hardware to mount the RM Racing rear bar.
http://www.dsmtuners.com/forums/420a-bolt-tech/343928-lots-questions-about-sway-bars-2gnt-fwd.html
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
