How to recirc. my HKS bov? Have fitting
idkiliketurbos
827
179
Mar 2, 2009
Appleton, Wisconsin
As the title states my HKS bov needs recirculating. It already has the 1" fitting on it, but the diameter of my recirc. tube on the intake pipe is about 1.25-1.5 inches. What could i do to get this recirculated?
What I actually ended up doing was buying a foot of vinyl fiber-reinforced tubing from Home Depot. This was big enough to clamp onto the HKS recirc section. The other end I had to force INTO the inlet pipe of the intake. The outer diameter of the tubing is a perfect fit for this, fitting snugly. The stock recirculation pipe is just too big to fit onto the HKS, which is sad. A picture is worth a thousand words, so just look below to see how I did it. It looks ghetto, but honestly it worked perfectly.
Before I sold my old setup.. I went to lowes with the fitting and picked up a small piece of hose for a dishwasher and used it as a sleeve on top the fitting then it worked perfectly with the stock recirculation hose.:thumb:
This works great. I have a small section of hose over the recirc fitting to bring it up to the I.D. of the recirc hose. Fits great, no problems.
Alright i got a peice of small hose to use as a sleeve and i found that because of where my BOV is mounted that the stock recirculation hose has the wrong bends so back to the hardware store tomorow.
  • Wanted 6 bolt NT water pipe
    • chrisman287
