how to pick the right amp
buddy3824
120
Mar 31, 2009
lexington, Kentucky
i got 2 kicker comp 12's in a box each with their own chamber. i dont want to over power. i guess the main thing, do i go for monoblock? 2 channel? whats the difference. how much RMS is a good number to stick with.
an easy way is to take the power of the woofer for example, (300 watts) and if since you have 2 i would say get a 2 channel amp, add both wattage's of you woofers together and get a amp which is rated to equal to that say a 600 watt amp, thats how i have always done systems and have never blown anything except a head unit.
if that's confusing i can try to re-word it.
What ohm and rms are the subs? This is what you use to choose and amp, not anything else. Also do you know if the box you have is the correct airspace or is it a prefab? Also how much do you have to spend, and do you have a brand you like in particular?
Darren
alot of amps these days support 2-4-8 ohms as alot of subs are made in that range so depending on how you jump the woofer it would be one of those ohms, unless you are running 1ohm big stuff or 0 ohm monster sytem.
Well you are also correct ^^^ The other thing is wether or not it is a dual or single voice coil.
i am unsure about the the specs on the subs. i got them used but i know they work. from doing a little research, from picture matching...
# 12" 4-ohm subwoofer
# polymineral cone
# double-stitched foam surround
# suitable for free-air use
# power handling: 50-150 watts RMS
# peak power handling: 300 watts
# frequency response: 27-500 Hz
# sensitivity: 89.1 dB
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
