How to Install new Door Boxes
My Drivers side door box was missing a small piece in the corner as well as my door panels felt weak and and is if they were falling apart.
Keep in mind, you will be working with quite a few plastic parts. Plastic is not strong and aged plastic is brittle. Take your time and don't Man Handle this procedure. It's a good time to clean the door panel up both inside and out.
I got the black door boxes as replacements. I think they add a nice touch. Here's how I did it.
Tools:
1. Regular Phillips Screw Driver
2. Short type Phillipse Screw Driver
3. Dremel Tool with Cutting Disc
4. Small Flat Head Screw Driver
I took detailed pictures. They are below.
