How to install a greddy turbo timer
WhiteNight
May 22, 2005
Pompano Beach, Florida
OK i just got a greddy turbo timer and could use some advice on how to install it cause I dont wanna mess something up. Some pics would be usefull. Thanks.
OK i connected the main harness but have 3 wires still a Brown, Purple, and a short gray 1 with a blue connector. Where do they go.
Take off the plastic around the steering column and look at the back of where you put the key in at. The ignition switch is there and follow it for about a foot and it will have a connector. Just pull the connector apart and plug the harness in.
flinguist said:
Here's the Greddy manual. It tells you in there. Here's the 2G ECU pinout. You'll need that too.
i dont get it, when im looking at the ECU the plugs arent in the same order as the ECU pinout picture on prostreet online? the pic shows the small plug (12 pins) one away from all the way left? on my car the 12 pin is all the way on the right? :confused:
all i need to know is where too hook up the vehicle speed sensor wire (purple one on harness)
i just tried setting it to speed at the 25mph but it didnt work, the turbo timer works fine but the digital speed read-out function does not, how is it getting the speed signal without the wire being connected?
just hook up the ebrake wire and be done with it. you may want to look around for the guide on wiring up the car so the alarm works with the turbo timer properly, other than that, you're fine.
SICK i found the wire! its yellow with a silver band on it if anybody would like to know. the whole time i was looking at the wrong harness:| stupid me anyways ill try out the speedo feature 2m and let you guys now if it works and sh!t, hopefully it reads in MPH not just Kilmeters\hour
