how to hook the a/f ratio gauge in..
www.vfaq.com has a faq I believe, but the 02 sensor signal where you have to hook up the gauge to is near the passanger panel piece right next to the door, under the dash. There are a bunch of wires there and I believe the one with the clip on it, is the wire.
I forgot exactly what connector it has on it, but some kind. Its the wire that ends, and doesn't keep going with the other wires.
Road Race
Go there. It is instructions for a Jumptronix o2, but it gives the ECU wires that need to be tapped and their description. That should be all you need besides the instructions that came with the o2 gauge. What is it, like a purple, black and red wire? The red is 12V supply, purple is o2 reference, and black is ground. All those wires are to be had from the ECU. Good luck
