How to get 2g shifting like NEW car?!
chelfy
77
Aug 30, 2004
La Crosse, Wisconsin
Hey guys, i'm going to be replacing my stock clutch soon, with an act2100, and I was wondering what other steps I could take while the car is apart to help insure my car shifts like new again (clutch fork, etc) :thumb:
I just put in ACT 2600 with new fork, throw out bearing, pivot ball. I also have new clutch lines (not installed) and I was thinking of putting in new shifter cables. Once I break in the clutch I'll let you know if it turned out ok.
Any other suggestions from anyone?
as for rebuilding the tranny depends on who you have do it and what you have done. ive got a friend who runs 9s and builds dsm transmissions for 800 i basicly got a shep stage2 trans i got new bearings seals syronros upgraded shift forks and rails i could of done doubble syroncros but didnt need them depnds on what you do
I personally rebuilt the trans steal braided clutch line act2600 clutch new shifter bushing inside the shifter 7 each for the dealer then i did the bushings on the shifter cables new shifter cables and the bushings that go into the shifter base inside the car as well. my car shifts pretty good but i think it will be even better once i put new motor mounts in 2 of them are destoryed
I could do a basic rebuild on a good core for about $300. I think the biggest gains I have noticed are in proper shimming, my trans shifts smooth as can be at 7500+ rpms without double syncros. When I am all broke in I will be shifting at 8500-9000 rpms.
Which short throw shifter?
Most people tend to go with the knock-off B&M short throw shifters sold on Ebay for about $30. I believe it's identical but needs a little modification to work. There's a big ass thread about them. For me, a short shifter, ES plate bushings, underhood bushings and BG Sync did the trick. I have my throw at 35% btw.
That would be your quickest/cheapest/easiest way to get your car to shift totally different. I think its one of my favorite mods under $50.00.
How does it change the shifting? Would people recommend short throw shifters in the eclipse? I never liked mine in my integra gsr, shifted very hard.
