How much tension should i have.
SmokeyGST
43
May 22, 2004
Houston, Texas
On my timing belt between the exhaust cam and the tensioner pully? I got paranoid after feeling the slack between the 2 cam gears but realized that can't reall ybe controlled. any answers will be helpful
It depends on how/when/where the motor stops. You can't base anything on the tension of the tbelt between the cam gears. Only way is to pull the cover and see how much of the tensioner piston is sticking out at TDC. In other words, unless you have another reason to believe something's not right w/the tension, then don't worry about it.
well the tensioner could still bend a nail so its still good i'm sure...guess i am being paranoid for no reason...
