about how much horsepower should i have
96Clipse4U
Mar 7, 2004
Lexington, Kentucky
i have the following mods i need a good estimate of how much horsepower i will have
50 trim
3 inch intake pipe
3 inch exhaust no cat
tubular manifold
aeromotive fuel pressure regulator
walbro 255
rc 550 injectors
hard intercooler piping
safc 2
hks 264/272 cams
forge blow off valve
manual boost controller set at 18psi
act 2100
and how many pounds do u all think is safe for daily use on pump gas and on race gas for the track
50 trim
3 inch intake pipe
tubular manifold
walbro 255
rc 550 injectors
safc 2
hks 264/272 cams
act 2100
Are you trying to run a 50 trim on the SMIC? :confused: :|
Here is a list of performance mods that the fella's here suggest, and the order they suggest them in. Looks like you are on that path, so check off the mods that you have done, sit back, and look at what level of tuning you are at.
http://dsmtuners.com/tuning-guide/2gturbo/
How does she feel? Do you drive the 50 trim daily? Let us know if you .25...
im having the fuel pump and regulator and 50 trim and cams installed this coming week and having it tuned on the dyno and im taking to the track but i wanted to see what people have put down with similar mods
Yea, definately get a bigger set of injectors. How much power you make is going to depend on how well you can tune it.
around 300 is what im hoping for at least but i dont know and i will be having horsepower house in lexington ky do the tuning on the dyno and i will step up to bigger injectors and a downpipe
Hey, another guy from Lex, cool. I know the guys at HPH well, they are good at what they do. I dont know about the hp estimate, but you should be able to ask them your questions and the would know pretty well. I may have to try to show up when you get it tuned. One of their guys used to come on here a lot.
And if there is any doubt about their tuning, a 10sec 1g and a 8or9 sec 4g63 starion speak well for them. good luck
Jesse
  • Wanted 6 bolt NT water pipe
    • chrisman287
