How much oil
youll need about 4... fill it with 3, then slowly add the 4th, and keep checking the dipstick (this should prove that your motor needs about 4 to fill)... you should also pour some oil into the oil filter before you screw it on. i also like to lube the seal on the oil filter too. put a tiny bit of oil on your finger and run it around the seal. then proceed to fill the motor :thumb:
