How much oil in tranny when changing?
AWDlaserRS
411
Nov 30, 2002
In the shop manual it says when changing the tranny oil to only put in 2 quarts because not all of it comes out when you drain it. and the capacity is 2.8. What do you guys put in when you change it? :confused:
BUCK said:
Make sure the car is level on 4 Jack Stands & put it in until it runs out the Plug on the Front Side - that's what that Plug is for.
:thumb:
If you don't do it that way either grab yah hold of someones or a shops lift for about 10-15 mins or make sure it's on level ground.
