how do you wire a fuel pressure gauge?
tkhaab_94
262
3
Aug 1, 2009
sacramento, California
I got this Autometer Fuel pressure gauge. I took it out recently because I put in my wideband. I didn't remember which wires go to this gauge. The back has three prongs where the wires are supposed to go. It says GND, S, and, I. I tried to wire what I thought was the correct wire and it didn't work. So which wire goes to which prong?
And no, the wires on it in the picture (red and black wire) do not represent Positive and negative.
I think I might of tried that, but I will try again. There is 2 wires coming from the sender. Which one do I use?
i would run the sensor ground to the gauge ground instead of relying on chassis ground to give you an accurate reading.
