How do you hook up seat belt harnesses.
Not sure what you want... are you wondering how to properly attach the harness straps to say a harness bar? Or are you wondering how to buckle up a cam-lock harness to strap yourself in?
Im thinking that I maybe missing a part or something. I will probably post a picture of what I have tomorrow
Yeah, post up pictures if you can't get it figured out. Assuming you installed everything correct, buckling up the cam-lock should be easy. I'd go over everything you've done and look over the instructions. Just make sure you've got everything in right.
The issue is that he doesn't have a camlok style setup, but rather a 5 point latch and link setup which are a little more confusing to use the first time.
well most 5 point harnesses ive seen if i am getting what he said about working it starts,crotch belt,left waist belt,right waist belt,right should then left shoulder
