How do you adjust timing on a '95 with no cam sensor???
perley03
585
14
Apr 29, 2006
Bangor, Maine
My friend and I were talking and he said that since I bought the car and knew zero history on the car to check the ignition timing to see if it was off. Now I don't have any problem with power or starting the car, he was just simply stating that I should, and of course we were bored. Anyways the timing belt and all components, including balance shaft, were all changed 10k miles ago. So he brought over his timing light, and I took some white-out and marked the TDC on the crank pulley and each degree mark on the front case. We started the car with the light hooked up to #1 cylinder and its reading 3-4* BTDC, it bounces around between these two. Idle is at ~800 rpms, a little below according to my datalogger. Now my datalogger says 5* at idle, so this leads me to thinking that my timing is off ~1*. I know that on my 1G all you had to do was loosen up the nuts on the cam sensor and adjust accordingly to your base timing. Well as you can tell I have a 2G and it seems to be without a cam sensor, that I can see. What do I do and how can I set my timing back to 5*?
Unfortunaltly on a 2g you cant adjust the ignition timing like on a 1g unless you get a 1g cas and swap it out. But yours being a 95 it also has a timing wire that you can ground to get a more accurate reading of what your timing is. Its located on teh firewall behind the itntake mani. Im not sure the color since mines a 97 and it dont have that wire. But you can search on here to find the wire because ive run into it a couple of times searching timing.
Yeah, I was looking at some diagrams and found that. But still, what if my timing is off a few degrees? We even checked the cam timing and it is dead on, using a straight edge and the cam bolts. I'm not worried about it, as my logs show I'm getting 20-21* timing up near 6200rpms.
