How do I wire the Injector resistor pack?
Take the 3 bolts out holding down the wiring harness onto the intake manifold. Pull the plastic cover apart and find the injector wires. Pick one of the yellow(in my case), thick ones (the ground wires) on the HARNESS side. Solder it to the white wire going into the resistor pack. Solder the black wires to the four yellow jacketed wires on the INJECTORs. The other thinner wires going into the injectors can be left alone. Tape up all your bare wires and tape the harness back together neatly and WATERPROOF. Bolt the harness cover back up.
What yellow wire? In the wire harness it's self? It dosen't matter which one?
Do I just Tap all the wires together?
