how do i remove the Torque Converter
Status
Not open for further replies.
igopoopy
2,051
7
May 5, 2004
tucson, Arizona
how do i remove the Torque Converter?
i dont want to F@$% any thing up!
yes it is apart id doesnt want to come out
Spin it and pull on it at the same time. It should come out then. Make sure its in the whole way when you put it back in. Spin it and push it in at the same time. It should "lock in" 3 times and its in the whole way. If you don't have in in right it will mess the pump up. It should sit back in the bell housing about 3/4" to 1".
i got it out i had to take the 4 flex plate bolts out
actually when you reinstall it should only sit back .64" more like 5/8ths of an inch not 3/4 or 1". that would be a little to much if you had a lot of trouble removing the TC(stuck on the trans pump shaft) it a sign that the pump might be damaged. just thought i should let you know.
I don't have one in front of me to measure it was an estimate. By the way 5/8 is .625 :thumb: .640 is 41/64
4g63swap said:
well anyway he should look in his chiltons manual. It will give him the exact measurement. :cool:
I agree. :)
i have one for my 1g :cool: and i have the dsm cd but it doesnt say any thing about the auto trany
Status
