hose that comes of the LICP?
I do and I don't know where it is supose to go. Also if I have a manual boost controller, Do I still need any vacuum lines running to the electronice wastegate actuator. I still have the one form the electronic wastegate acuator to my intake tube.
The only hose I have down near there is the one coming from my wastegate actuator. Is it that?
Nope, get rid of the BCS completely.
Ok, this is how your boost controller hooks up. You have one line going from the wastegate actuator to the mbc, then you tee into the line from your bov to the intake mani and connect a hose from there to your mbc. Then you can get rid of the bcs and plus the hose on the intake.
I will give it a try. But I still have a vacuum line on my LICP that will be going to nothing then. Also so you arre saying that I should kust leave the one on the intake tubo open and no vacuum line?
I meant to say plug the nipple on the intake. Is there anyway you can take a pic of the hose on your LICP?
possibly I could, I will try to see if I can tomorrow. I hooked up the stock BCs and it is runnign fine, but I really want to hook up my MBC. Thanks for your help I will try to get that picture.
