punishercb
- 466
- 0
- Jan 25, 2005
La Porte,
Indiana
Out of nowhere my car is starting to screech. The sound seems to be coming from the driver wheel but I'm not sure. It's happening when I turn left really sharp or hard. It sounds like there's a damn pop can stuck there.
I checked around the brake from under the car and didn't see any odd marks or scratches. Any ideas??
now for the fun part. bang away until it comes out. alot of times this wont work, so u will have to take it to a shop or to a friends house that has a press and press it out. its alot faster and easier that way. then make sure the area is cleaned out, pack the bearing with grease, and then get back to the press. press it in, make sure its even, and install the grease seal. (seal is less than $10) make sure everything is installed on knuckle again, and then reinstall the knuckle back on the car. make sure everything is tight, and then road test vehicle.
