Horrible misfire help
talontsi98
92
Feb 23, 2007
Roseburg, Oregon
Here's the deal. The car runs fine until it is warmed up. When it is warm any you come to a stop it will start missing and run on about 2 cylinders. If I disconnect the battery and reconnect, it runs fine. Compression, plugs, wires are good. The tards at chevron did put 89 in instead of 92 on last fillup.(have evo3 16g) What would cause this?
check boost leaks...was it miss firing before you got that cheap gas put in?? it could just be really REALLY crappy gas.
