Hooking up HKS EVC ON 16G from T25
StarDiamond
217
Sep 30, 2003
Waterford,
I was looking at my new 16g and found that there is only one vacume line to hook into and there are two for the HKS EVC on the t25? Anyone have suggestions??
if its an internally gated turbo there should only be 1 vaccum line going to the actuator, and then another line from a nipple on the compressor housing. IF you don't have one there then put a source nipple right where the lower intercooler piping starts and hook the 2nd line to that.
I dont understand why you would need to tap into the intercooler pipe. If you run the line off of the throttle body, wouldnt it be the actual amount of pressure going into the motor, especially since you have a pressure drop across the intercooler, anyway? I just finished an install on a T04B H3, and came across the same problem. Any thoughts on this....
