wearurpjs
- 58
- 0
- May 4, 2004
chi-town,
Illinois
ok, now before I get bombarded, Ive searched and searched and I havent found a problem similar to mine, let alone close. Although I could be wrong.
allow me to clarify...I put on an HKS SSQV on my car earlier this week, started her up, and I was shocked when it sounded just like my old one(crushed 1G BOV). upon further inspection, I realized, I had never been blowing out the BOV at all, rather it sounds like its coming out of my intake..!? Im out of ideas...spent the weekend looking for a vaccuum leak, removed my manual boost controller and reconnected the stock boost solenoid and all lines...so the vaccuum line from the manifold is going straight to the bov...and still the same. the sound changed though, its not as loud/long...still comin from the same spot. and no, nothing is coming out of the BOV, I put my hand in front of it, nothing comes out. at all.
some pics...here we go...
one line of the tee going to the comp. pipe...
other tee to the wastegate...
source from the intake manifold going directly to the BOV...
in. mani. vac source going directly to the BOV
these 2 lines, there not pulling vac. at least I dont think. I pulled them off with the engine running, didnt really notice a hesitation or change in idle.
engine bay shot
and there it is...still cant find any problems with the lines i have hooked up, theyre all where they should be...any help would be much appreciated my fellow DSMtuners.
engine bay shot
You can probably do the same with the 14b... it isn't that much bigger than the T-25.
you do have a boost leak and you should have a higher idle.
