Hks Bov Help
Sterlingsxe
38
Feb 5, 2005
Manalanapan, New Jersey
Ok guys. Went to install this thing tonight. Looked pretty easy. I got the old one off with a little strugle seemed to want to stay in place. Then i got to the HKS ssqv. I put that little rubber ring in first. Then they gave me a c clip to hold it in place. I cant for the life of me get that little c clip in the flange to keep it in place. How do i get that c clip in the flang to hold it? Any tips advice. Well and also i looked at the flange. And it is smaller then the other bov so it fits in the pipe pretty loose. But i figure i can just clamp it in there. SInce it is the right part. I just need help with that c clip thanks guys...
Using a small allen key, take the outer housing of the BOV off. The screws facing toward where the air exits the BOV. This will give you more room. Use a set of Criclip pliers or some needlenose to get it in, and don't ofrget the oring that goes in there. Lube it up with a little bit of grease first.
