hks bov help
90redtalontsi
265
Feb 15, 2009
lancaster, Pennsylvania
ok guys so after my rebuild everything is hooked up and fixed most if not all of the vac leaks and boost leaks but when the car is at idle the hks ssqv bov has some air coming out of the front mostly the bottom right hand side and im not sure why i have a turbo xs mbc and im not sure how to hook that up to the bov and waste gate does anyone have any ideas:confused:
I've always heard that the SSQV would never leak due to the design. If it has O-Ring seals in it you might want to disassemble it and check out all of the moving parts and O-Rings.
+1^^ Also about your MBC, There should be a Vacuum line coming from your intake through your MBC to the BOV.
Edit: After laying in bed last night thinking about this I realized that I had a large brain fart and what i meant was no that so please ignore
Hmm, well you've got me stumped. The good news is HKS stands behind their products, so you should be able to get a replacement or a repair. Sorry I can't offer more help.
