Hissing when clutch depressed
HyperGSX
1,170
Oct 10, 2002
Schaumburg, Illinois
when i press the clutch in, it makes an air hissing noise kind of like a vacuum leak. However, my car runs perfect and i hit the boost im supposed to be getting. Btw, the noise seems to be coming from under the steering wheel area
Clutch slave cylinder is likely leaking. While you're at it, you may want to replace the master cylinder as well so that you don't fix one thing and have another crop up.
Hope that helps,
Andy
Sorry to bring back a dead thread but did it turn out to be the slave cylinder? I have the same hissing from where the pedals are when i fully press the clutch.
