high idle and lean read out
iLOL@Vtec
Feb 19, 2013
Chicago, Illinois
ive been reading and reading forums after forums and stil cant figure out why my 98 gst wont idle right. when car starts idles about 1200 then a minute or so later jumps up to 2000 and my air fuel ratio reads a very lean mixture.also car is drinking gas horribly like im not bs ing but I get less than 9mpg also did a boost.leak test and nothing so I ran out of ideas. any help please.
does it bounce between 1200 and 2000?
sounds like a bad TPS to me
if youre sure theres no boost leak its is definitely a sensor, do you have a CEL?
Your running in open loop mode reason for gas mileage. You have a vacuum leak, bad tps, misadjusted tps, bad isc, etc. Need more info like leak tests, cel? When it started, what your were doing to it before it started.
tested my isc checks out good also tested tps sensor good also
I adjusted the tps and dropped idle back down to 1000 but still idles bad and smells like its running insanely rich
when I baught the car it was stock still is stock but the upic had a boost leak fixed that and still did a booat leak test and fixed all my small leaks I can do another just to make sure also no CEL
