High IDC's?
screwdgie
254
4
Apr 6, 2003
Barrington, Illinois
OK I'm running 15 psi on a 14b with a 190 pump and stock 450's. And yet I am seeing duty cycles over 100%, sometimes as high as 115%! I am positive there are no boost leaks, as i tested for them and it held 20 psi fine, then I took the car to DEVO tuning and they also did not find any leaks either. I don't know what could be causing such high duty cycles!? I removed the lower honeycomb in the maf and pulled back the screw, would hacking more off the bottom portion help my situation? Anyone have any insight on this?
Stock injectors with all the bolts ons you have will cause the high DC. You have to remember your flowing a good bit of air and the injectors cant really compensate. You could go with a keydiver chip and will probably bring them back down a bit because it will compensate for what you have, but regardless, time for an upgrade. :thumb:
Joe
Slowboy Racing
I see what you are sayingg, but even back when the car only had a catback and on 15 psi, i would still see like 95% which seems high also. But regardless I just picked up a free 2g mas :D and I will be adding some 550s and afc shortly
