hid wiring
thisdsm
294
Feb 18, 2004
so cal, California
can someone tell me which is which? There are 2 sets. Im assuming for the first set, the blue is + and the white is - ?? For the second set, Im assuming the blue is + and the black is - ?? Out of the those 2 sets which ones are the ones I need to switch around for it to work?
I am 90% sure you just turn the plug around that goes into the H.i.d. box. Not the two in the picture!
Hmm, the only plugs that goes into the HID box (ballasts) are the ones Im holding. And I don't really want to pull my headlights out again. Does anyone know which set of wires it is?
I went ahead and spliced into the set that has the fishnet wrapped around. Worked right up until I cranked up the motor and then the driver's side went out on me. I'm going to have to pull it out tomorrow to see if the bulb is burnt.
