Hesitation and cutting out at WOT
mitsuman18
53
Oct 2, 2003
Live Oak, Florida
It just started happening after my last time at the track. I used some 110 octane. It started right after I put the gas in. Let the tank run almost empty then filled it up with 93 and some lucas fuel system treatment. Changed my plugs (which looked fried) to some BPR7ES's. The car has not changed at all. It still feels like a big loss of horsepower and it still misses like plugs. I'm running 16 psi. Plugs are gapped at .030. Also have some brand new 8.5 mm wires. Any ideas?
i am having the same problem as you explained did you ever diagnose the problem? let me know what it was thanks
Have you checked/changed your plugs and gapped them correctly
Maybe need to replace fuel filter.
thanks man right after i posted that i took the plugs bak out n re gapped them .28 and shes pulling hard not problem
thanks
  • Wanted 6 bolt NT water pipe
    • chrisman287
