toppertopper
- 444
- 0
- May 14, 2009
edmonton,
AB, Canada
Well i will have my transmission piece soon (hopefully)
Timing belt , water pump , oil pump already done ..Susspension (shocks and springs) done, rear chamber kit done
Installed : turbosmart manual boost controller (set at 15 psi) boost controller hooked up ..hid kit installed not hooked up , will be removing this
no vac del yet..
Not sure what kind of hp range i want, just going for the goodies and see where it lands me ..On a stock block for now untill it blows up
Also going to install a 255 fuel pump.
Now we begin the question i have for upgrades
#1 I was told get a gm maf (have one 3.5) and hook up a maft and a vented bov..But i have been reading , map are the way to go ? need some explains for both
#2 Still has stock exhaust with cat ..Also reading 2g 02's are better flow ..But do i go 3" back with the 2g 02 housing?
#3 What wideband and why
#4 Looking to go ecmlink of course .. Now do i just go ecmlink or ecmlink with sd (still need to read up on sd)
#5 What injector size can i use ..Something that i can run with out over running everything but still get full potential..Also what fpr
#6 Anything else i might be missing
I am making a list at the moment, before jumping into it head 1st to fall on my face
no vac del yet..
