here we go agian.'putting'
dsm4lifebeoch
37
Apr 29, 2004
tampa, Florida
I having a small problem with my 2g, the car just had a 6bolt conversion done and little modification like a lighten flywheel balance shaft removed and is running of 16psi of boost. Last night I was cruising down the bridge I was do about 100mph got and came to a light at idle it car stated to putt so I rev up and it with a way then it happened again and this morning it was worse. When the car warms up it slows down if you guy have any information on what this problem can be please inform me thanks in advance…. Juan :dsm:
there are tonz of things that could be contributing to your problem. sounds like maybe a vacuum leak somewhere. check and make sure there aren't any loose or not connected vacuum lines. i had a similar problem in my 1g, on the intake manifold, right on the TB, there was a little connector that had worked its way loose. i reconnected that, and it fixed the problem....hoped that helped....... :talon:
