Help!!!!
TRBOGSX
Jan 23, 2003
I have a 7bolt bottom end from a 95 Talon AWD which I admit I should have changed over to 6 bolt but I didnt so here is the problem. I put a 1gen head on as well as intake manifold. The problem is that my thermostat housing will not match up to my coolant pipe that runs across the front of the motor to the water pump and I am not sure what to do. The first pic with the two red things circled are what need to be connected but I cant do that b/c the 2gen bolt holes wont line up on the 1st gen head. The other pic is the two beside each other and the the thing circled in red there is the part that goes to the coolant pipe....can someone plz help me
As 1fast97gsx said with the link to RRE this is what you need
- The big water pipe on the front of the motor (MUST be May/90- newer)
- The complete water neck assembly on the side of the motor (MUST be May/90- newer)
- The "u" shape water line that goes under the turbo (any year 90-94)
Looks like your still trying to use the 2G pipe to me.
