Help with Stuck Flywheel
X10NEO
Apr 29, 2005
phoenix, Arizona
I have a fidanza flywheel that has been on the motor for about 2000 miles. I am trying to switch it to a different motor but the flywheel won't come off. i have all the bolts off and i used liquid wrench, but to no avail. i have tryed a prybar and even a slide hammer but all the slide hammer did is pull some of the aluminium out with it. Any Ideas? Thanks
Nick :talon:
The last thing you want to do is hit the aluminum with anything, even a slide hammer.
Try hitting the steel ring gear on one side with a rubber mallet, then switching to the oppisite side.Hit it fairly hard (common since hard)
-Chad
