HELP with right front end
ericismyname
682
Oct 14, 2002
West Des Moines, Iowa
Okay i did a front passanger side outer cv boot replacement.
i did it through this: http://www.vfaq.com/mods/CVboots.html
and i also used my hanyes manual for help. when i was taking off one of the brake lines to move the hub i broke a metal hydralic line,..which i replaced and bled the right caliper so the brakes work.
okay so here is the problem. when i drive the car it feels as if im rubbing on something or something is not moving with the rest of the car as if it were a dragging it along with the car instead (not draggin on the ground type of drag) at first i thought it was my lugs not being tight enough becuase turned out i did forget to retighetn them all the way. but that was not it. any ideas? its not leaking any fluids anywhere so i think the axle seated itself back in becuase vfaq said it woudl leak like crazy if it had not. HELP i need this car beucase it is my only car and my Daily driver.
Okay my suspicion is not enough grease in the CV boot. is ther a way to put more greas in without taking it all bakc out again :cry:
  • Wanted 6 bolt NT water pipe
    • chrisman287
